Good evening everyone,
I submit this little problem on which I tear my hair for too long. on the dynamic block as an attachment, I would like to make a window with only one leaf but with the possibility of controlling the size of the window between masonry.I did a chain action on the window opening parameter which itself controls the stretching and the scale of the leaf.
the problem is that when I mirror the whole, the line of the leaf goes very far and stretches uncontrollably.
Can you help me please ?
thank you
Solved by Libbya. Go to Solution.
Here's a step-by-step screencast that shows how to do what you are asking for. Let me know if you get stuck or have questions. Screencast in followup post.
Magnificent!! thank you thank you Andrew for saving me.
I managed to reproduce it, but I admit that I still don't understand the logic very well. I would like to understand why it is necessary to externalize the parameters window openning for this to work?
in any case a big thank you
