Message 1 of 14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to create a dynamic beam block that stretches vertically and horizontally. The issue I'm having is that I can't get the stirrups (represented by the dashed line) to stretch without the corners deforming or warping. The next issue I'm having is that I have slab block with a wipeout. The same issue, I want to be able to stretch the block with both directions with the wipeout following the shape. I need one end open so that this block can be added to other drawings where there isn't a cold joint when connecting to a beam. Thank you in advance.
