Stretchable Array
Stretchable Array
lrodgersL3G4V
Message 1 of 15
Stretchable Array
lrodgersL3G4V
Can you have a stretchable array? I want to have a rebar end array to every 2" but also every foot.
Does that make sense. I want to be able to section thru the rebar in a concrete slab every foot (multiple rebar), but also be able to put it in a thickened slab or bond beam at 4 to 6" apart for only 2 of them. Right now I have it with a 1' array.
Replies (14)
Message 2 of 15
j.palmeL29YX
Would you please post an example of the expected result, so we can see your intention.
Jürgen Palme
Message 3 of 15
lrodgersL3G4V
In the jpg below I have the top rebar arraying at 12". And I'd like to also be able to array it at 4" like the bottom rebar.
Message 4 of 15
j.palmeL29YX
I must confess that I still don't understand your intention.
Therefore, I'm attaching a first draft as a basis for discussion.
Jürgen Palme
Message 5 of 15
MMcCall402
How about something like this:
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 6 of 15
lrodgersL3G4V
those are 2 separate arrays on 2 rebars correct? I was wondering if it could be done with 2 arrays on the same rebar?
Message 7 of 15
lrodgersL3G4V
Or if you could select the array spacing before you actually array it.
Message 8 of 15
MMcCall402
My attempt does use two separate arrays, but they're within the same block.  A single bar diameter selection sets the bar size for both arrays. A visibility state selection chooses if there is just one row of bars or two.  When there are two you get the option of selecting the vertical separation between the two rows.
Mark Mccall
CAD Mangler
Linkedin
Message 9 of 15
lrodgersL3G4V
Neither of these solutions is what I was looking for.
What I want is to select the rebar and then stretch it to 12" spacing and then select a second instance of the same block and be able to stretch it at 2" spacing.
Message 10 of 15
j.palmeL29YX
Based on Mark's suggestion this next rough attempt.
Jürgen Palme
Message 11 of 15
lrodgersL3G4V
That is closer to what I need. I would need visibility states for 4" and 6" spacing. Now I can not have visibility states for the different sizes of rebar. Unless a double lookup table would work for that?
Message 12 of 15
MMcCall402
Here's a second attempt.  This one uses the ARRAYPATH to do the array of the bar(s).  There are three of these, one for each size bar.  The spacing of the bars is a User Parameter. (types in to the spacing value of the arraypath's properties)   There is also a Block Properties table that supplies possible values to the spacing user parameter.
Mark Mccall
CAD Mangler
Linkedin
Message 13 of 15
lrodgersL3G4V
I have it working with 12 visibility states. But now I'm wondering if it can be done so its easier for the user if we used a double look up?
Message 14 of 15
j.palmeL29YX
@lrodgersL3G4V wrote:
... it can be done so its easier for the user
perhaps using a block property table?
Jürgen Palme
Message 15 of 15
j.palmeL29YX
Or, if you urgently want to use double lookup, try this.
Jürgen Palme
