Stretch dynamic block within dynamic block
- Mute
- Permalink
- Report
Can somenone tell me if this is possible?
I use a diferent blocks for each weight, the block needs to be strechable to adjust to the wall thickness, it works well.
The set of block i'm using serves my propose weel for year.
Now i want to be able to adjust the frame detail independent from the door leaf, for that i want to replace the frame geometry by a block (this metod works for me in multiprupose doors - i change the frame geometry in the frame block anda all the door blocks get the frame updated).
EDIT: Blocks added
06-PMad-PMN-1f-850.dwg - the base block
06-PMad-PMN-1f-850dyn.dwg - the base block in progress with the frame block inserted
The old geometry was deleted and replaced with my new frame block strechable (1)
Now i cant make the frame grip to work with the door grip (2), is it possible?
Thanks in advance.
