Stretch commands doesn't reverse when flipped
Hi all
Attached a block with an ongoing problem I've been having. In the attached block, the stretch parameters works as intended, but when I flip the block, the stretch actions on Distance2 parameter doesn't reverse, and it messes up when you stretch it.
What am I doing wrong?
ojuris
I think problem is with 3dface
If i change 3dface to polyline - it's working
I should have mentioned that I need them to be 3D faces / or any faces that has a visible area in 3d view, as I am going to stack a lot of them on top of each other - so I can't have them being polylines 🙂Capture.PNG
ojuris
try this
@ojuris wrote:
try this
Brilliant idea with the double lookup to visibility - If you add the Distance3 part to the Stretch1 parameter, it works exactly how I wanted it to! 🙂
Thank you!
