needed help with dynamic blocks of door and window,,
madhuryya_prakash
Message 1 of 19
madhuryya_prakash
Hi,i have created dynamic block for door and window.
I want the flipping grip of door to be at centre when it is stretced.
Also the arc for the door opening is correct at its original size,but when stretched there is offset seen on the blocks.
Kindly help to avoid those offsets.
In the window i want the alignment grip to be at centre when stretched vertically.
I am new to the dynamic blocks creation any help is highly appreciated.
Thanks in advance.
Replies (18)
Message 2 of 19
For the flip parameters on the door, you forgot to add the arcs to the flip action.
Regarding the arrows for flipping, I suggest adding a MOVE-action to your distance parameter, then open your properties window - click the move-action and change Distance Multiplier in the Override tab to 0.5 instead of 1.
Have a look at the attached file
Message 3 of 19
Regarding the scale-action, if an object is X percent smaller than the distance it is attached to, the scaled object will keep that X percentage in difference. If you change the distance parameter to be the same width as your arc, all you need to do is make your Scale-action base type Independant and move it's base point to the center of the arc.
Attached updated block again
Message 4 of 19
madhuryya_prakash
Hi ,Thanks a lot for the reply and solution,i was trying it out,and it is working...however i have one doubt though, how did you move the stretch grip to this corner as shown in attached image
Message 5 of 19
madhuryya_prakash
Hi,Thanks a lot for your reply and solution.
Message 6 of 19
Without anything selected, simply click the light blue grips (make sure only the grip is highlighted), and move them with the blue square that shows up in the selected grip 🙂 Or select the grip in the same way as mentioned, and specify an offset distance in the properties window
Message 7 of 19
madhuryya_prakash
Thanks for the reply,i am attaching the file once again showing the problems i am getting.:)
Message 8 of 19
I think your best choise in this case would be to add a lookup parameter to your door block, but I'm not an expert on lookups - Hopefully someone else would be able to help 🙂
Message 9 of 19
madhuryya_prakash
Hi, Thanks for the reply.Surely will look for a solution and let you also know about it.
Message 10 of 19
ojuris
hi!
look attached file
Message 11 of 19
madhuryya_prakash
Hi,Thanks for your reply,its working great.:-)
Message 12 of 19
madhuryya_prakash
Dear Ojuris,i am able to do the door dynamic block as per your solution.However i am facing this issue while developing further,could you please look into this.,Thanks in advance...PFA
Message 13 of 19
madhuryya_prakash
Please refind the attachment.
Message 14 of 19
ojuris
look attachment
Message 15 of 19
madhuryya_prakash
Hi Ojuris,
Thanks for the solution,its working fine now:).Further to my working i came across this issues as shown in the attached
drawing.Could you suggest how to resolve this.
Also if you could explain what steps you took to solve the previous issue.
PFA
Message 16 of 19
ojuris
I add Stretch and Stretch1 and Scale actions in Flip1 and Flip3 actions
To do that you must have BACTIONBARMODE = 0
And I think you must correct your block. Stretch frame for action Stretch3 must include all doors and arc.
Message 17 of 19
madhuryya_prakash
Hi its working now,the arc issue is resolved,
as per your second comment, 'Stretch frame for action Stretch3 must include all doors and arc'
I did this,after which the door frame is stretching in one direction only.
Thanks for the genius solution.
Message 18 of 19
ojuris
hi!
About stretch frame size - you don't understand correctly
Message 19 of 19
madhuryya_prakash
Hi,Its working great now,Thanks a ton for your support.I had limited access to PC,hence could not reply to you on time.
