Stretch and keep align and flip grip at the mid point
Joe-Bouza
Mentor Mentor
Message 1 of 13
Joe-Bouza
I dont have access to the block to share but it is a simple rectangle i stretch and would like the align and flip grip to stay at the midpoint. What is the work flow for that?
Joe Bouza
Replies (12)
Message 2 of 13
Libbya
Without seeing how you have the parameters set up, it is just a guess, but my guess would be to add another stretch or move [edit]action[/edit], add those two parameters to its selection set, and change its distance multiplier property to 0.5.
Message 3 of 13
Joe-Bouza
I will let you know. sounds good. Can that stretch parameter have zero grips?
Joe Bouza
Message 4 of 13
h_s_walker
@Joe-Bouza Yes. Just change the item ringed in the image below to 0
Howard Walker
Left Handed and Proud
Message 5 of 13
Libbya
I misspoke previously when I said "add another stretch or move parameter".  There is no such thing as a 'stretch parameter' or 'move parameter'.  There are stretch actions though which can be associated with several kinds of parameters including linear, polar, XY, and point parameters.  Actions do not have grips so there is no such thing as a stretch grip or said another way, stretch actions always have zero grips.  Parameters have grips and you can turn them on or off in properties.  You can associate any number of stretch actions with a parameter point and that parameter point can have its grip on or off as desired.  The 'distance multiplier' is a property of the individual stretch or move actions so you can have two actions associated with a single parameter point that has its single grip turned on.  One of those stretch actions can have a distance multiplier of 1 and stretch the edge of the rectangle exactly as far as the grip moves.  The other stretch action can have a distance multiplier of 0.5 and move the centered objects 1/2 as far as the grip moves and so keep the centered objects centered regardless of how far the grip/parameter point is moved.  Hopefully that all makes sense.
Message 6 of 13
Joe-Bouza
Where do I find the distance multiplier?
Joe Bouza
Message 7 of 13
Libbya
You have a linear parameter selected.  As I mentioned in my last comment, the distance multiplier is a property of the stretch action.  You need to select the action, not the parameter it is associated with, and then look at the properties palette.
Message 8 of 13
Joe-Bouza
that's the grip number. it is a list?
Joe Bouza
Message 9 of 13
Joe-Bouza
Pardon my dense head but im not getting it so fast.
Joe Bouza
Message 10 of 13
Libbya
Slowly reread my comment that is message 5.  It details things very specifically.  I'll try again.
PARAMETERS have grips.  The number of grips they have and how many are shown are one of their properties.  You can turn the grips on/off by selecting a parameter and changing their grips property on the properties palette.
ACTIONS are associated with parameters.  Any number of actions can be associated with a parameter.  The move or stretch actions have a Distance Multiplier property.  You can alter the distance multiplier property by selecting the action and changing the distance multiplier property on the properties palette.
Parameters do not have any distance multiplier properties.  Actions do not have grips.
Message 11 of 13
Joe-Bouza
I appreciate you taking the time to explain. I am fairly well acquainted with dynamic blocks and the parameter / actions. Where I fell short in my desperate cry was I don't follow how to make one action link to another parameter per se.
I have the multiplier
I'm not sure how to select the object or get distance2 to to stretch with distance 1
Joe Bouza
Message 12 of 13
Libbya
Your Distance2 linear parameter is superfluous.  You should add BOTH stretch actions to your Distance1 linear parameter.
Message 13 of 13
Libbya
In looking at the block you posted, you will also need to remove the flip and alignment parameters from the Stretch action that has the distance multiplier of 1.  They should only be included in the selection set of the second action that has a distance modifier of 0.5.  For that second action I would use a move rather than stretch but either can work provided your stretch action window completely surrounds the two parameters you want to move.
