Stretch and flip
Stretch and flip
Message 1 of 49
Stretch and flip
Hey guys,
I am trying to creat a dynamic block that stretches evenly on both sides and also has a flip command. I can't seem to get these commands to work together properly. I got the block to stretch correctly but if I flip the block more than once it doubles in size.  Attached is my file I am trying to use. Can anyone help me? I need to be able to flip the block in any direction and stretch both direction simultaneously.
Accepted solutions (3)
Replies (48)
Message 21 of 49
What version are you saving it with? I am using 2010... Still won't let me open...
Message 22 of 49
Libbya
I am using 2013 but have slected to save to 2010 each time.  I'll try hosting the block in another drawing and backsaving it that way.  Here it is:
Message 23 of 49
Worked! Thank you! Now I am really sorry for asking this. I tried to mention it but I don't think you saw the comment. By any chance can we put the FSD text on the opposite side? I know that is getting a little much but I just realized that it would read better that way...
Message 24 of 49
Also is there a site to kind of guide me through these step so I don't have to rely on others and can start making my own blocks that are this complicated? I do really appreciate your help but I would eventually like to be self sufficient.
Message 25 of 49
Libbya
You can move them where you need them.  Making the FSD always to the left of the M or always to the right of the M regardless of which side of the block they are flipped to is a little harder.
Message 26 of 49
Is this something you would be willing to do for me? Or is that getting too in depth?
Message 27 of 49
Libbya
There are a few YouTube videos on dynamic blocks and I've seen a few other write-ups.  Mostly you just need to play around with them enough to get an understanding of what does what.  In your block right then, you needed to add the FSD to the selection set of a stretch and the flips.
Message 28 of 49
Libbya
None of this block is particularly difficult.  Do you always want the M to the outside?
Message 29 of 49
I understand that aspect of it but I don't understand how to fix the over stretching issue... I mean I can get it close to what I want but I am not experienced enough to get it perfect as you do...
Message 30 of 49
Libbya
Like this?  The FSD and the M should move the same amount.  You can go into block editor and move them to where you want them in relation to each other or the end of the block and regardless of where you place them, they should always move together.
Message 31 of 49
Yes, always on the outside. and always on the opposite side of the "FSD" text. It is because depending on what side we have the "M" shows which side of the Fire Smoke Damper we want the Motor on. So it shall be installed that way.
Message 32 of 49
No, I was thinking more like this...
Message 33 of 49
Libbya
Ah, ok.  Here it is again.
Message 34 of 49
wr.marshall
Used the example of "flip stretch 2010.dwg" posted by Libbya as a basis and tried to follow the logic as closely as possible. I am probably about 90% there as I can get the text to flip normal when at the bottom but when the text is at the top it us unexpected positioning when you stretch the length.
as you will see in the drawing file, I have the same block 9 times. below is a description of what is happening in each position. Mistakes with some of them are denoted with *
  1. original block
  2. stretched block
  3. flipped stretched block
  4. stretch block
  5. stretched flipped block *
  6. stretch block
  7. stretched flipped block *
  8. stretched block
  9. flipped stretched block
Additional information is that I have made use of multiple visual states. The type will change the symbol. Qty will determine how many symbols shown (Array), ROV handle put a handle on the object.
below is a screen shot for interest of what each control does
Message 35 of 49
wr.marshall
  1. original block
  2. stretched block
  4. stretch block
  6. stretch block
  8. stretched block
Message 36 of 49
Libbya
I think you ought to start your own thread for your block.  It is not really the same issue.  You want the text to move if it is not flipped and not move if it is flipped.
Message 37 of 49
Libbya
This screencast shows how to stretch when flipped one direction and not stretch when flipped the other direction.
Message 38 of 49
ndikesh
Hi Libbya,
Can you please upload a video so that I can copy it step by step.
my block is quite similar, just need to flip the object from left to right. As you've already mentioned, after flipping the object then stretch to wrong direction.
Message 39 of 49
ndikesh
Hi Libbya,
Just noticed the screencast was on the second page. That would solve the problem, however if I wish to stretch object from midpoint what are the changes I'll have to make?
Message 40 of 49
h_s_walker
Change the base location of your parameter from STARTPOINT to MIDPOINT. See the image below
Howard Walker
Left Handed and Proud
