Simplify dynamic block
I have a dynamic block that has a drop down list to select options A-E, which each contain different values for the same set of parameters. I would like to change this block so that it is just option E (so no drop down at all, basically a normal block with parameters controlled by the block properties table), and that A-D are not used. To do this, I deleted all the other entries from the block properties table. However, after I save this block with only the data for option E in the block properties table, when I go to use the block it still defaults to the values for A.
Is there a way to update the block so that changes the default values in the block editor?
