SIMPLE WALL SECTION DYNAMIC BLOCK
nikm42Q9N
nikm42Q9N
I'm looking for a simple Dynamic block (or lisp) that would create a simple wall section
with options on stud thickness or cmu , air space, installation thickness, Drywall... etc
Either a dynamic block or a routine similar to the inputs on how Revit makes walls
This is for 2d wall sections only
pendean
Community Legend
Community Legend
Why don't you post your 'simple' wall section and it's variations, lets see what you got and wish to convert into a single DynBlock.
timothy_crouse
Take a look in these files, you will see a dynamic block wall partition that may help you.
Best Regards
-Tim
nikm42Q9N
Was able to take yours and "reverse engineer" what I wanted. thanks allot
timothy_crouse
f you made another wall type would you mind sharing it?  Could always use another wall in my library.
If not I understand.
-Tim C.
Bamcosd
Good afternoon Tim, thank you so much for uploading your blocks they are a huge help to my learning. I have a question about your "Wall Partition Dynamic" block. You have the top track and insulation separated from the main body of the partition and I have to move the top track individually? Why is that? Just curious. Thanks again.
