Select XY-Parameter Increment
thomas_schluesselberger
is it possible to change the increment value of an XY-Parameter via lookup action (or some other kind of "selectable" thing).
Libbya
No.  You cannot dynamically alter the increments of any parameter.  It is possible to replicate that behavior in a limited way through the use of visibility states and copies of the parameter that have different increments.
OK, too bad.
But in this case the visibilty states should do the job.
Thank's for your answer.
