Copy a block with same constraints
spufut
spufut
Hi! I have a block with constraints and i want to make a copy of it to use in the same drawing but with different parameters. Is there a way to do that?
Thank you!
Libbya
On the save menu within block editor is the option to 'save as'.  That lets you copy the entire block definition to a new name.  The new definition will initially contain all the same parameters/actions/objects/constraints and can be edited from that point however you like without affecting the prior block definition.
