See existing parameters in dynamic block attributes
I am trying to edit a dynamic block for a window system. When inserting a triple window, the center window width does not change, while the outside windows change as they should. I believe that I need to add a new attribute, but I need to see the parameters for the other two attributes so I set the new one up the same. The block is attached here - can anyone help with this?
Libbya
Here you go.  I just added the appropriate linework/attributes to the Stretch1 and Stretch2 selection sets.
Beautiful! It works perfectly, and I opened it initially in block editor so I could follow what you did. I can amend the rest of our blocks from here - you are a life saver!
