Announcements
Saving an existing Dynamic Block out of a drawing
bwhisenhunt
bwhisenhunt
I have a dynamic door block that was created to allow several actions to occur.   Unfortunately, the WBlocked file was deleted before it ever got backed up.   I still have the block in a floor plan I just don't know how to export/rip it back into it's own file without blowing all the parameter/actions that took me forever to set up and get working right.   How can I get this back without having to recreate it from scratch?   I have attached a drawing where I stripped all but a portion of the base file.
Replies (8)
Alexander.Rivilis
What about using commands _resetblock and _wblock this block into file (see attachment):
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
MetalFingerz
There are multiple ways to achieve that. The only pre requisite would be to have both the "door in fp" drawing and a new one opened.
- Then you could use ADCENTER to visualize the block in your "door in fp" drawing then double click on it to insert in the new drawing.
- You could copy/paste it from your "door in fp" drawing to the new one.
- You could also drag and drop the block from your "door in fp" to a palette. Then click on it from the palette to insert it into the new drawing.
There are more but that's what I have in mind at the moment. All those solutions keep the block dynamic.
bwhisenhunt
I tried that but it lost all but the current visibility state.  Thank you.
Alexander.Rivilis
As I see in my dwg-file enough visibility states. What wrong with it?
Expert Elite Member
Alexander.Rivilis
Video of WBLOCK your dynamic block and inserting it in new dwg:
Expert Elite Member
Libbya
Similar to wblock, you can also open the block in block editor and use the open/save pulldown to select Save As.  Then check the box to save as file.
bwhisenhunt
You were correct.   I don't know if the purge didn't work or what happened but when I tried inserting it again it worked fine.  THANK YOU!
Charles_Shade
Haven't tested but dragging and dropping from DesignCenter should be an option as well.
I lost a DynBlk once and searched using DesignCenter to find it in a Drawing File from some time back.
