Rotating text in dynamic block
Good afternoon, I have a problem in a dynamic block where I need to put a parameterof rotation only atributado text that is contained in the block however when I apply the parameter text goes off the block and does not rotate on its axis, where I could bemissing? (pardon my English, I am Brazilian and write through a translator)
Libbya
Anything rotated by a rotation action will rotate around the rotate parameter center point.  Move the parameter so it is at the center of the triangle and your text will rotate within the triangle.
Similarly, a scale action will scale relative it's parameter's base point unless it is set to 'independent'.
You really should not ever place the base point parameter anywhere other than the 0,0 point in the block unless you have a very good reason for doing so.  It can cause problems.  Instead, adjust the linework/parameters/actions so that the base point is at 0,0 and where you want it relative to the other objects within the block.
If it were my block, I would center the triangle on 0,0.  I would place the linear parameter base point at 0,0.  I would place the rotate parameter base point at 0,0.  There is no need for any constraints.  There is no need for the base point parameter.
OK thank you
IkaroFalcao
Opa Renato, tudo bem?
É isso que você quer?
Opa era isso msm amigo,porem ja resolvi,acontece que quando eu colocava o parametro por algum motivo o texto não girava em torno de seu eixo,refiz tudo em um arquivo novo e deu certo,mas valeu,muito obrigado
serkancavuslar
DynamicBlock Rotate Text and Scale Block
Serkan ÇAVUŞLAR
CplCAD / Türkiye
