11:30 AM
Ok have a quick one... I've attached a receptacle that I'd like to add text to the block. But what I'd like the text to do is "rotate" with the receptacle but always stay in the correct orientation. You can see it in the example I've attached. I know I can manually move the text and rotate it but is there a way to always keep the text in the same location according to the rotation. Can this be done? Can this be done if I was to make the text and attribute?
-Jason
