Rotate parameter angle minimum changes between visibility states
peterjwinberg
peterjwinberg
See block. Please find your way to 36"x48" shower with Swing door.
I set the angle limits for the door swing, but when displaying this size shower the door cannot swing all the way to 270 degrees. Can someone tell me how to fix this so it can "open" all the way?  It works fine when displaying the "base" size, so I imagine it has something to do with it stretching.
Thanks!
Libbya
It is because you are stretching the rotation parameter rather than moving it.  Remove the rotate parameter from the stretch action and add a move action for just the rotation parameter.  That will fix the issue.
peterjwinberg
Once the rotate parameter is on its own move action, then add the move action to the stretch or add the move action to the lookup? I'm having mixed results.
Thank you!
Libbya
The move action should be associated with the Width parameter.  Do not add it to any stretch actions and you cannot add a move action to a lookup parameter.  In essence instead of stretching the rotation, you need to move it.  See screencast.
