- Mute
- Permalink
- Report
Hello Friends,
I need your support to rotate an antenna in plan view with respect to north direction ( North = 0 degree) in clockwise direction. When I am importing this block to a drawing, I feed azimuth of that antenna in the dynamic block label for rotating ( Say 33 degree, 255 degree etc.). The problem I am facing in attached block is, it rotates counterclockwise direction only when I input positive values ( I need them to move in clockwise direction with respect to north till 359 degree) . Also, when I feed 270 degree it rotate 270 degree in counter clockwise & then changing value in label to 90 degree immediately after that is not doing any modification in the drawing.
