rotate attribute
rotate attribute
salelukov
rotate attribute
salelukov
Can someone help me how to set up this block to rotate only the attribute?
rmarkowitz
Are you looking to set it's permanent rotation? It's in the properties of the attribute.
Or are you looking to make it parametric?
If so, are you looking to keep it parallel with the view, or rotate it arbitrarily?
Libbya
salelukov
i want to rotate only attribute (text) in model space, and rectangle to stay unrotated. sorry, i am not so familiar with AutoCAD
Libbya
That's exactly what I show in the screencast.
Libbya
If you want a different axis of rotation, then move the rotate parameter so that it centers on the point around which you would like to rotate.
