How to create a dynamic block with array and also strech
Alan_w12
Alan_w12
Hello to everyone
I need some guidance, I`m trying to create a dynamic block, this will be the basis of a huge crane library, and this step will help me go faster.
I want to create a block where "object 1" (  the mask )  as they go up ( array)  also "object 2" go ups as well ( stretch)
I know that it`s a combination of these two parameters, I got lost in the process in the order of the commands.
I will appreciate any guidance and advice, or any other ways to make this block possible.
Hope I was clear.
Thank you in advance
vinodkl
Check the below screencast🙂 Since I don't have the drawing I have just drawn the "object 1" and "object 2" with some dimension. I have taken the length of "object 1" 300 as shown in the image as 30"(2'6")
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Alan_w12
Thank you vinodkl!
I got lost while trying to do it,
thank you for the example!
