Reset to Original State
kzD1219
kzD1219
I have a dynamic block, thanks with the help here.  I am able to move text around and rotate the arrow along with the text.
My question is after playing with it for a bit, changing the visibility gets a bit confusing.  So is there any way to reset the block to its original insert state?
For example, this is what the block looks like when inserted and the visibility changed to 2 slopes.
After modifying it to move the text and rotate it, it may look like this:
Any way to 'reset' a dynamic block?
Libbya
The command RESETBLOCK will let you select the dynamic blocks to reset to the default values.
kzD1219
Great thanks!  That was a little too easy.
