Polar Stretch, Rotation limit
sscott9G46T
sscott9G46T
Hi I am trying to limit the rotation on a polar stretch between two points but i am having difficulty because the rotation passes through the 0 degree's mark. I want to limit between 32 degree's and 350 degree's (clockwise).
i have drawn a basic block to show what i am trying to achieve.
Thanks.
j.palmeL29YX
Perhaps a crutch like the attached (?)
Jürgen Palme
Libbya
Of course, you could also separate your polar stretch into a linear parameter/stretch and a rotation using a rotate parameter/action.  A rotate parameter would allow you to limit the rotation to your desired angles but allow all angles between.
