Please help for the dynamic block.
cenga_06
cenga_06
I have some questions within the DWG project.
It is for placing materials by entering values.
Thank you in advance for your help.
MMcCall402
I think this might be workable.  An Arraypath within the block with its "path" controlled by constraints.  A couple user parameters to calculate the number of objects in the array and spacing using the overall length and a maximum (Max) spacing value.   The Total_Length and Max values can be edited in the properties palette after the block is placed.
One thing I couldn't get in there was the flip action.  When I put it in it would work once and then stay that way.  Might be that instability issue of mixing parameters and constraints in the same block.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
j.palmeL29YX
Confirmation.
I have also never managed to get a flip action to work in a constraint-controlled block.
BTW: Constraining the both construction lines to be horizontally would increase the stability of the block.
Jürgen Palme
