Perpendicular
Perpendicular
algirdas.kaupas25
Perpendicular
algirdas.kaupas25
I'm making dynamic block with angle, and i want to leave some line perpendicular, please help me to do this, 🙂 Adding what i am doing .
Libbya
Here you go.  Let me know if you have questions.
algirdas.kaupas25
Thanks for your answer, working on it. Can you help me: on one computer i can insert by hand some value of dimension, but on another i can't , how to enable/disable that function, thanks.
h_s_walker
At the command line type DYNMODE. Change the value to 1
Howard Walker
Left Handed and Proud
Francisco_Melo
Hello everyone.
Thank you Libbya. Thank you very much for your videos, as always they are a great help to understand and develop our skills.
j.palmeL29YX
... or, only an additional alternative to the solution of @Libbya , use more precise values for the overrides of the stretch action (see attached dwg).
And of course you have to correct the direction of the Distance1 parameter to be horizontal.
Jürgen Palme
Libbya
Indeed, that's a fine way to go.  Here's how to use the method I used in the last video to arrive at the more precise values for the stretch overrides.
