Bom dia,
Alguém sabe me dizer como parametrizar uma objeto que não esteja no mesmo eixo?
- Preciso parametrizar uma geometria oblonga e com uma altura diferente preciso parametrizar um circulo, quando eu movo o circulo para cima ele perde o parametro, e não deixa parametrizar a geometria que não esteja no mesmo eixo, segue exemplo
Solved by Charles_Shade. Go to Solution.
Translation:
Good Morning, Can anyone tell me how to parameterize an object that is not on the same axis? - I need to parameterize an oblong geometry and with a different height I need to parameterize a circle, when I move the circle up it loses the parameter, and does not let parameterize the geometry that is not on the same axis, following example
Can you attach the Dynamic Block please?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I'm going to say no.
The Stretch Frame is 2D and as such has no height. When you move the entity out of the plane where it is originally created the Frame is removed from the entity. I do not think that Parameters can be made to move through the Z Axis
It's as though the Stretch Frame does not include those Entities in the Selection Set.
(But I expect someone will come along and prove me incorrect)
Do you need the two entities to change size together?
Do they need to be tied to one another somehow?
