Object in Dynamic Block should be stretch equally but on 400 or less
Message 1 of 62
I am learning dynamic block & i have attached here one dynamic block & mentioned in that what kind of action, constraint  i need in that block. please guide me.
When i stretch this block, i want to all holes between first hole and last hole are in equally divide but distance between two holes should be 400 or less than 400.
Please see uploaded cad file for details.
Please help me out from this.
Replies (61)
Message 21 of 62
j.palmeL29YX
For B type anc C type you first have to decide which dimensions you want to change - the continued dimensions or the baseline dimensions (see pic).
Then you can do it nearly the same way as shown in my video(s) above. Where do you have problems? Show us what you have and what not works as expected.
What you have shown in your attached dwg at the A type I don't understand. Please tell us again where you want the holes be placed.
Jürgen Palme
Message 22 of 62
Please attached calculation for that A type new holes.
Message 23 of 62
Message 24 of 62
j.palmeL29YX
Columns E, C, F?
Please attach the complete Row.
Jürgen Palme
Message 25 of 62
It's hide in the excel.
Please see attachment
Message 26 of 62
hi
Message 27 of 62
Could you please guide me....
Message 28 of 62
j.palmeL29YX
Sorry, I'm on vacation right now.
Either you wait about two weeks (until I'm back again) or wait until  another user helps.
Jürgen Palme
Message 29 of 62
j.palmeL29YX
Don't worry. Now I'm back again and did a closer look at your .ods file.
The formulas in this file only provide a reasonable result if "Dimension" (column C) is greater than or equal to 800. Is this the intention?
I am a little irritated because in your picture in Posting No. 22 all dimensions "Dimension" are smaller than 800.
Do you want the distances between the holes really always be equal to 400, as it is defined in your formula and only the "End Dimension" varies? This is feasible (but also reasonable only, if the "Dimension" is greater than 400), but before I make the effort to make a video I want to be sure to understand what you really want.
Jürgen Palme
Message 30 of 62
j.palmeL29YX
In the meantime I built a block "Test-pa" for the C-Type block (see attached _A CARD (1)-pa2a.dwg) in a manner as I understand your intention.
You can change the horizontal dimensions D_hl, D_hm and D_hr (for the left, the middle and the right section) as well as the dimension D_v for the vertical dimension using the properties window or the grips. The distance between the holes is 400. The dimensions D_el, D_em, D_er nd D_ev (for the End Dimensions) are calculated. The smallest allowed value for the End Dimensions can be set with the parameter D_emin. (properties window).
I hope this is close to what you want.
Jürgen Palme
Message 31 of 62
j.palmeL29YX
A small bug fixed ...
Jürgen Palme
Message 32 of 62
PLEASE SEE ATTACHMENT .
Message 33 of 62
j.palmeL29YX
Still one question - see attached dwg.
And an additional question (only for my interesting): Why do you extend the white lines, what is the sense of that?
Jürgen Palme
Message 34 of 62
Actually, both the holes are required, cyan colour is rivet holes & magenta colour holes are weep holes.
Rivet holes for all sides and weep for only bottom of panel.
Message 35 of 62
Actually, both the holes are required, cyan color is rivet holes & magenta color holes are weep holes.
Message 36 of 62
j.palmeL29YX
That I understood in the meantime. My question is about the Rivet holes. In your example we can place 6 holes (and the end disctance is 385) or also we can place 7 holes wirth an end distance of 185. In both variants is "150 < end distance < 400" (this is your condition). I'd prefer the last variant - is it allowed?
Jürgen Palme
Message 37 of 62
Sorry, for the end distance minimum 200 and maximum 400 is allowed.
Message 38 of 62
j.palmeL29YX
Now it makes sence. 😉
I will post you a solution in the late afternoon.
Jürgen Palme
Message 39 of 62
PLEASE SEE ATTACHED CAD FILE.
Message 40 of 62
THANK YOU SIR
