Not sure how I keep something in the middle while stretching/changing size of geometries around it
nilswa
nilswa
I want to create a parametric constraint that spaces a wall evenly/ in the middle of a geometry/room. Every time the geometry is resized on either side it should still be kept in the middle. How do I do that?
j.palmeL29YX
First you need some additional constraints to full constrain the geometry.
Then you can either set d2=d1  (or d1=d2)
or you add a coincident constraint endpoint of the vertical line to the midpoint of the horizontal line.
>>demo<<
BTW: This issue has nothing to do with dynamic blocks (until now. We don't know what you further want to do)
Jürgen Palme
