Message 1 of 8
I have a block with an attribute that contains an ellipse. When the text/attribute gets too long, I want to stretch or scale the ellipse so the Y distance stays the same, only the X distance will change. So far i have tried to use the XY parameter, the linear parameter and others to no avail. It always changes both X and Y. I tried creating a block inside the dynamic block hoping to use a constant scale but it did not work as well. When you select a grip on the block itself, it works. How do i get it to do what i need it to do?
