Need to Scale Ellipse in x direction Only
JamesCarr1956
Message 1 of 8
JamesCarr1956
I have a block with an attribute that contains an ellipse. When the text/attribute gets too long, I want to stretch or scale the ellipse so the Y distance stays the same, only the X distance will change. So far i have tried to use the XY parameter, the linear parameter and others to no avail. It always changes both X and Y. I tried creating a block inside the dynamic block hoping to use a constant scale but it did not work as well. When you select a grip on the block itself, it works. How do i get it to do what i need it to do?
Replies (7)
Message 2 of 8
Libbya
I do not know of a way to scale ellipses in the single direction.  The issue has come up before.  Here's a technique/block I developed a while ago.  It uses splines to simulate an ellipse.  It is not actually exact but darn close as you can see by the blue superimposed on the white ellipses.
Message 3 of 8
j.palmeL29YX
Something like this? (see attached dwg)
cadder
Jürgen Palme
Message 4 of 8
JamesCarr1956
That IS pretty darn close. Thanks for your response. I will try and use this in my block. What about the block? If I make it as a block inserted, can I just scale it on the X axis and still keep it as an ellipse?
Message 5 of 8
JamesCarr1956
Thanks to all. I like both responses. I tried the restraint, but not the way you have it. Not sure why I did not see that. DOH!
Message 6 of 8
j.palmeL29YX
... and here a little better (IMO):
[some minutes later]: my final suggestion in ...new2.dwg
cadder
Jürgen Palme
Message 7 of 8
Libbya
I had tried that before, by attempting to individually add the coincident constraints and they will not work with ellipses (only the center point shows up).  I had not tried using auto-constrain.
You should add a gripless linear dimensional constraint to the Y axis in order to prevent it from changing.
Message 8 of 8
j.palmeL29YX
There IS a Rotated Dimension (DCLinear -> d1) to hold the vertical stable. In the block editor start DCDISPLAY an pick the vertical construction line to turn the visibility ON.
But thanks for your attention, though.
cadder
Jürgen Palme
