Hi @GB-CHHQ5
Try not to duplicate the post in different forums. Please try to maintain a single post to get a better solution to your question🙂 Duplication the question would just confuse you with different solutions provided in different forums.
I see you have posted in this question in AutoCAD, AutoCAD LT, and in here.
https://forums.autodesk.com/t5/autocad-forum/multileader-with-block-and-mtext/td-p/9696520
https://forums.autodesk.com/t5/autocad-lt-forum/multileader-with-block-and-mtext/td-p/9696530
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
