Mtext Field to populate current X and Y position
christian_paulsen98V29
Hello all!
I've got a block that i use to dimension electrical utilities in my drawings. Right now the longitude and latitude are attributes that have fields in them to populate the x and y position. The problem is that i wanted to attributes to not show up in the properties pallet anymore, since i will never want to input those values manually.
I tried a few different approaches. The first being that i made the attributes constant so that they no longer showed up in the properties pallet when i had the object selected. But when i did that it made it to where the x and y values no longer are automatically updated.
The second approach i tried was to get rid of the attributes and replace them with mtext. The issue im running into is that when creating a field the "block placeholder" was no longer available, so i instead used the base point object and got my x and y off that. I think its pulling x and y from the blocks 0,0 though, and not the global 0,0.
Anyone have any ideas on how i can get the longitude and latitude to auto populate, while still keeping them from showing up on my properties pallet? Ive attached the dwg file with all 3 versions for you to use and play with.
Bump.
h_s_walker
There is no way to have them not show up in the properties palette. To keep them out of the way I would right click on one of them and use the attribute order from the shortcut menu to "move" them to the very end of the attributes. See the image below
Howard Walker
Left Handed and Proud
