09:59 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am a beginner with AutoCAD. I am working on creating a block that is able to move across multiple .dwg files that are various scales. I have a block that was created in a 1:1 scaled portrait sheet. I have been trying to get it to scale correctly on a 1:8 portrait sheet and will need to work for many other scales. I have been trying to use the DWGUNITS command because I previously found something online saying that might work, but have had no success. The block is still appearing very small. Can you help me out with something that might work?
Thank you
