Move diagonal polar stretch vertically
Message 1 of 10
Hi people,
I'm working for a few weeks with Dynamic Blocks, but I have a problem. In my Dynamic Block is a diagonal polar stretch action/parameter. This parameter is on the bottom grip attached to another diagonal line and on the top grip attached to a horizontal line. On the moment I want to move the horizontal line vertical the top grip moves good and the other diagonal line also, but the bottom grip of the polar stretch stays on the same place. How is it possible to move the bottom grip correctly?
Sorry for my bad English.
I hope that anyone have a solution.
Replies (9)
Message 2 of 10
ojuris
post your block
Message 3 of 10
In the attachment a easy sample of my problem.
Message 4 of 10
ojuris
how your block must work?
angle between diagonal line and horizontal line must be constant?
Message 5 of 10
When the highest block on the left is moving vertical, the bottom triangle of the polar stretch also moves with the diagonal line
Message 6 of 10
ojuris
sorry - I don't understand
may be you can sketch some variants how block must look after moving ?
Message 7 of 10
Sujan.Maharjan
This is all I understood. How you want the highlighted portion to behave?(jpg file)
"Revit Lies in the tension between what we want to do and what can be done!"
Message 8 of 10
The highlighted portion muss still stay on the diagonal line. It means that it also make a angle.
Message 9 of 10
marco_martinez
Hi
in order your rectangle maintain itself as a rectangle apply perpendicular constrain a dimensional constrain, then apply colineal between the base of the rectangle and the diagonal line. This will resolve your question
Message 10 of 10
Emmsleys
Following up on your thread, it looks that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
