I am creating a lookup because I want two drop-downs menus in one block. In this case, it is a sink that can be simple or double and then circular or squared:
![aitorm_1-1647621516588.png aitorm_1-1647621516588.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1038105iDE6FDCABB2BFB900/image-dimensions/211x100?v=v2)
![aitorm_2-1647621546550.png aitorm_2-1647621546550.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1038106iA5C74B11F9CFFAF5/image-dimensions/210x119?v=v2)
![aitorm_3-1647621615023.png aitorm_3-1647621615023.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1038107i583479E605230A5F/image-dimensions/221x106?v=v2)
![aitorm_5-1647621686665.png aitorm_5-1647621686665.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1038109i75F20AC7B9023E6E/image-size/medium?v=v2&px=400)
When I change the lookup, the first sink must move to create room for the second one and the countertop becomes bigger. The problem is that if I want to move the position of the sink or the size of the countertop, it tells me "personalizado" because it doesn't match the lookup default.
![aitorm_7-1647621992205.png aitorm_7-1647621992205.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1038111i51F2C30CE312E6B6/image-size/medium?v=v2&px=400)
Of course that is like that because I named it so:
![aitorm_8-1647622323823.png aitorm_8-1647622323823.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1038112i21C6F79F9AA51117/image-size/medium?v=v2&px=400)
Do you find a way to show countertop size and sink position and at the same time than number of sinks and shape?
Thank you so much
