Meta-Data of Dynamic Block into Title Block
jcsteele560
jcsteele560
Is it possible to broadcast meta-data of an AutoCAD block (dynamic or non-dynamic) into a title block?
I work with numerous ACAD blocks and need a faster turnaround.  Can anyone share a recommended procedure?
Brock_Olly
You can use fields to reference attributes inside blocks but they will have to be setup manually so that's probably not what you need.
I think a LISP solution would work better here but you'd have to describe your situation in more detail.
