Meta-Data of Dynamic Block into Title Block
jcsteele560
jcsteele560
Is it possible to broadcast meta-data of an AutoCAD block (dynamic or non-dynamic) into a title block?
I work with numerous ACAD blocks and need a faster turnaround.  Can anyone share a recommended procedure?
Brock_Olly
You can use fields to reference attributes inside blocks but they will have to be setup manually so that's probably not what you need.
I think a LISP solution would work better here but you'd have to describe your situation in more detail.
CGBenner
@jcsteele560
Hello, do you still need help with this question?
Chris Benner
csteeleU2Z9C
Hi.
If I drawn an AutoCAD block - say a cellphone for example.
Brand:  Apple
Model: IPhone 8
Colour: Black
Dimensions: 1350mm x 650mm x 100mm
Can this AutoCAD block, with meta-data attached to it then broadcast this meta-data into a title block?
Brock_Olly
Yes this is entirely possible if that meta-data is made out of attributes.
You will need a custom LISP command and custom title block.
Head over to this forum for help with custom LISP solutions:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/visual-lisp-autolisp-customizat...
