Lookup Dimension
Lookup Dimension
Sujan.Maharjan
Lookup Dimension
Sujan.Maharjan
I added Linear dimension property in Lookup. But for some I want that to be (AS IT IS/UNCHANGED).
Autocad does not allow reverse lookup without putting any value.
"Revit Lies in the tension between what we want to do and what can be done!"
ojuris
hi!
I don't understand what you mean
Could you explain a little more precisely?
Sujan.Maharjan
Hi @ojuris
I mean how to leave blank in highlighted area for Duct length parameter with reverse lookup enabled.(attached screenshot)
marco_martinez
Hi
May be you could send an image of your block or your block so I can help you
Libbya
I am quite sure I can offer a solution if you post the block.
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
