Linking attribute values to the Block name.
lakshmankumar.satya
lakshmankumar.satya
 My Dynamic Block name Is " Rectangle" It should be Updated with attributes stretching Value for example "500X1200 Length". So the dynamic block name should be 500X1200 Length. Is there a way to update dynamic Block names with attributes.It is for data extraction.
MMcCall402
Edit the block name based on attribute values?  No
You can extract the dimensional attribute values in a data extraction.
You could place a hidden attribute within the block collects values within the block thru fields and assembles them into a single attribute to use for extraction.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
lakshmankumar.satya
Hi MMcCall402,
    Thanks for your reply .Is there any info regarding the subject you have mentioned earlier or any links about them.
lakshmankumar.satya
Hi MMcCall402,
                      Finally i got the point what you said earlier and my problem were solved. Thanks MMcCall402,.
