Linear Stretch Increment Distance
bbrems3K829
bbrems3K829
I have a linear stretch in one direction. I set the incremental distance to .125 and the min 1'0" and max 10'0"
When I input the length I am wanting it changes to a smaller size.
Example: I input 2'0" and It changes to 1'11.938".
How do I get it to stretch to the length I need?
Thank you!
Beth
Libbya
Your Pipe Length linear parameter is drawn at 1'-8 9/16".  You have a 1/8" increment set.  You are starting with an odd number of 16ths so you will always land on an odd number of 16ths due to the increment.  If you want to access the 8ths, then draw it at an even 8th or set the increment to 16ths.
bbrems3K829
Thank you!
