Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the attached dwg, the block on the left uses a linear stretch parameter to change the visibilty state. The profile changes as the depth of the U hanger increases. Distance is set to change visibilty state via double lookup. This method works with right side (r) profile only. I would like to toggle between side and front (f), and be able to stretch the profile as needed for allowed sizes in either view. The block on the right has the front views built in, but I cannot figure out how to configure the lookups properly.
End result:
Pull down menu - Side view or Front view
stretch up to change profile
Thank you
