line doesnt work after stretch and flip
the line doesn't attach in the right location after I stretch and then a flip.
I included the line and circle and point in the flip.
do I need to include the above in the stretch?
Thanks for the comments
Vinayv4v
While applying the flip action you need to select all the objects in the diagram (slot, line & the circle)
But for stretch you only need to select the slot (by using cross selection method)Dyn1.JPGdyn2.JPGdynamic.JPG
Thanks & Best regards
Vinay
Cheers,
Vinay Vijayakumaran
yes, thank you very much.
Emmsleys
Following up on your thread, it appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
