Attribute unlinks to change name and property of sheetet
Edwin.Saez
Advisor Advisor
Edwin.Saez
How could I automatically redirect to the custom property that corresponds to an attribute, if I change the name of the custom property of the sheet set? . Since when I modify the name of a custom property of a sheetset, I have to go to the attribute inside the block, to re-link with the faithful to the modified property of the sheet set.
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
Libbya
You seem to answer your own question.  The 'automatic' way would be not to change the name of the custom property...  If you have to change the name of the custom property, then change the field also.
