Limited values, labels warning
algirdas.kaupas25
Message 1 of 13
algirdas.kaupas25
I'm making dynamic block with limited value. I want to make to appear label or warning if my linear parameter is, for example, min value is 40, max is 200, but then value is 140 I need some warning or label that measurement is above 140, because we are manufacturing from wood and from 140 is changing material ?
Thanks for your answer
Algirdas
Replies (12)
Message 2 of 13
Libbya
No problem.  See screencast.  Let me know if you have questions or get stuck.
Message 3 of 13
Libbya
Message 4 of 13
Libbya
Message 5 of 13
Libbya
Message 6 of 13
algirdas.kaupas25
I can't find double lookup in autocad, I see here is autocad arhitectual
Message 7 of 13
h_s_walker
Lookup double lookups here. You need to make it. It's just two lookup actions connected together
Howard Walker
Left Handed and Proud
Message 8 of 13
algirdas.kaupas25
 Could you show me how to do it, step by step ? 🙂
Message 9 of 13
h_s_walker
I don't have screencast, but below are two images which should help
In the first I have made a copy of LOOKUP SET and called in LOOKUP2 SET.
Right Click on the copy of your lookup set and then choose PROPERTIES.
Now look at the second image
Click on the ACTIONS section and then click on the little square to the right of LOOKUP. You can now add another lookup
Howard Walker
Message 10 of 13
vinodkl
Hi @algirdas.kaupas25
AutoCAD out of the box doesn't come with a Double lookup. You need to create one🙂
Check this link on how to create double lookup: https://forums.autodesk.com/t5/dynamic-blocks-forum/how-to-make-a-double-lookup/td-p/5785708
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 11 of 13
algirdas.kaupas25
I'm still stuck on Property lookup table, I chose distance 2 , and then i want write what you write (.145), and next one (145.) and then i press enter it's gone , why ?? what i am doing wrong ?
Message 12 of 13
Libbya
You have the values wrong.  In the screencast that I posted I used the range values of (,145) and [145,).  Notice that those are commas and not periods.  Also notice that the second range value starts with a bracket and not a parenthesis.  The way that range values work is described in the autocad help (with errors in the writeup) and I have described on this forum where a search will find it.
On a side note, it seems strange to me that you marked all the posts in this thread as the solution except my posts that contain the screencast that actually show how to do what you asked to do.
Message 13 of 13
algirdas.kaupas25
Thank you a lot, for your patience , now I done what i want.  🙂
