keeping lines intersected when rotating independently
I have two polylines that intersect each other on a construction line.
I want to rotate the two polylines independently, but at the same time stretch so they always intersect on the construction line.
I have tried using the coincident constraint, but that changes the shape of the polylines.
what to do?
marco_martinez
Hi
Have you try making the the polyline coincident with the vertical line, not the second polyline (use the OBJECT option inside the coincident). If you want no deformation in the polyline try whit more constraints, dimensional too
Let me know if It was useful
Hi!
Tried that with both geometric and parametric constraints, but the polylines alway find some way to deform, often in a way I believed was locked by a constraint. The only thing it doesn't do is stretch to the vertical line.
marco_martinez
Look what I did and tell if that is what you want, I only did it left side to compare
Thanks Marco,
That worked perfectly. 🙂
marco_martinez
Great
