I have watched video after video and thought I had everything straight, but I still can't get the attached to flip on the wall right after changing the frame width. The door size change and vertical flip works, just can't figure the horizontal. Can anyone point out what I'm missing?
Solved by j.palmeL29YX. Go to Solution.
Substitute the Stretch5 action by a Move action (assoziated to the sam parmeter [Thickness], the same Multiplicator [0.5] and the same selection set [Flip state2 parameter]).
Not yet full tested.
Jürgen Palme
That worked, but also found my flip location needed adjustment for it to work as it wasn't dead center. Thanks.
I've seen that before too, but since this behavior occurred even before changing the thickness, I assumed that was your intention. But I think everything works fine now... 😉
Jürgen Palme
Oddly I swore before stretch it was flipping right, just after stretch it went bad. Playing with it so many times to get it to work I might have moved the flip and saved. Either way, glad you helped me find a solution. Confusing to use stretch command for one way, but have to use move to go the other way.
