Issue w/Rotation Parameter in Dynamic Block
Community,
I need some help.  I'm trying to create a dynamic block that will be used as a section cut.  This section will need to be stretched and rotated.  I've got everything working the way I want, including keeping the text horizontal as the rest of the block rotates.  However, as the block rotates the 'circle' separates from the 'arrow'.  What am I missing?  I've attached the .dwg file.
Thanks in advance
Libbya
I just posted in the other thread...
The 'Stretch' action associated with Distance1 is messing it up.  I'm not sure what you are trying to accomplish with it.  It seems like you might want a polar stretch instead and in that case, you will need to do a chained point move on the items in the other circle as well.  See attached.
