Is it possible to tie multiple linear parameters together?
Jonathan3891
Advisor Advisor
Jonathan3891
For instance, if I set the "Dia" parameter to 1.5, can that parameter be applied to N1, N2 and N3 without having to manually change them?
Jonathan Norton
Blog | Linkedin
Libbya
Sure.  You can add any number of actions to DIA and have them stretch the linework that N1 and N2 affect along with stretching N1 and N2.  You can do similarly to N1 and N2 so that any changes to any of them are reflected in all of them.  If you want more specific control, such as having certain ranges of values of DIA result in specific values for N1/N2, then look into how double lookups function.
Jonathan3891
Could you share a screen cast showing how to accomplish this?
My experience with dynamic blocks is very limited.
Jonathan Norton
Blog | Linkedin
Libbya
Nope, screencast was discontinued by AutoDesk.
