Interesting block
Interesting block
braicodavid
Interesting block
braicodavid
Hello.
I have a block I would like to create but not sure how to achieve it.
It's a simple cross brace symbol that cam adjust to any 4 points - as shown attached.
The issues are this;
1. having a gap between the lines where they cross.
2. Having the rectangle move with the line and correct orientation.
Would this be possible?
h_s_walker
This should give you some ideas
Howard Walker
Left Handed and Proud
jayhar
In block poly line are not intersection
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
ojuris
may be this is ok?
braicodavid
Thank you,
That is exactly what I was trying to do.
I will attempt to create my own version based on this now that I better understand how to accomplish this.
Thanks again,
-David
braicodavid
Thank you for your post.
sorry for the late reply, the Autodesk forum do not load properly in my browser.
That block was pretty much what I was going for just, I needed the lines to freely move not just extend.
I appreciate your help.
-David
braicodavid
Thank you for your help,
I have issues with the forums loading in my browser which is why it took a while to reply.
I think I have my solution with the following post.
Thank you again,
David
