inserted image disappear from cad drawing when location of image changed.
JHK19
JHK19
I have created a block to show the common detail of parts we manufacture but when I insert it into a drawing it is not correct.  It is showing huge center marks for the radii and some of the text or attributes are not in the correct location.  I created this block using AutoCad 2014.  It did not have these issues until I updated to 2019.  I would appreciate any help.  This is very frustrating.  Thank you.
h_s_walker
PDMODE and PDSIZE are the variables which control the shape and size of points. See the links below for more information
PDMODE
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
PDSIZE
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoC...
Howard Walker
Left Handed and Proud
JHK19
That was it.  Thank you.
