Inserted Blocks Not Showing up in printing
When I insert a downloaded block it shows up on my model screen. When I try to print it, it turns into white lines (so its invisible except for where it is overlaying on other layers).
I have tried moving it to other layers
I have tried matching properties to another layer
I have exploded it and grouped it together with no changes
If anyone knows anything about this, I would appreciate the help!
The "better work" file is the one I am trying to attach to the "bridge" file
Vinayv4v
Welcome to Autodesk Forums.
Your block does not seem to be in its layer color. It has got a different color set, that's why you are not able to print that block. You need to change the blocks layer color to (set by layer) option.
For that just type SETBYLAYER command and select the block fully or type all for all objects and hit the include the blocks option. Then all your layer colors will be set according to layer and you will be able to print the block.
Cheers,
Vinay Vijayakumaran
Hi Vinay!
Thank you for your response.
I have tried to enter the "SETBYLAYER" command and nothing is coming up, is it possible there could be another command layer for this?
-Carson
Vinayv4v
Please find the attached drawing.
SETBYLAYER
ALL
Y
Y
I wonder why SETBYLAYER command not working with you.
Which version of Autocad are you using?
Cheers,
Vinay Vijayakumaran
2015 -- it is the only one that works on my MacBook Pro
Best,
Carson
Vinayv4v
Please see the post for MAC Version.
https://forums.autodesk.com/t5/autocad-for-mac-forum/setbylayer/td-p/2918294
Anyway glad it worked.
Please mark the Accept as Solution button if my post solves your issue.
Cheers,
Vinay Vijayakumaran
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
